Search the Community
Showing results for tags 'exhaust manifold'.
Hello everyone. Just got done moving my High Compression EJ251/EJ25D hybrid from a '96 Legacy Wagon into a '98 Outback. Along with it I put in a JDM import 5mt from an '05 Legacy GT Turbo wagon. 4.11 end range. This motor and this transmission makes a perfect ride. All except for the fact that the exhaust manifold is in contact with one of the steering rack hydraulic lines. Rattles like a woodpecker jack-hammering the side of your house at 0500. I'm assuming the heat from the manifold will not be good in the long run. This was not a problem in the '96. What gives? Are there taller/shorter exhaust manifolds? Are there any super thick exhaust manifold gaskets that I should be aware of?
- chatter
- power steering
(and 4 more)
Tagged with:
Morning! New user here, but not new to car repairs. So due to one issue which we thought was the catalytic converter but it was really the ignition coil, we are now at a lovely junction of exhaust issues. We had already taken the old cat off and purchased a new one (Evan Fischer brand, if you're curious). But the flange on the exhaust manifold was too rusted for a proper seal with the gasket. If we buttoned her up from back to front, the exhaust leak was at the cat/manifold junction; from front to back both the cat/man junction and the cat/resonator junction had exhaust leaks. So I took the cat back off and was cleaning up the exhaust flange which was rather rusted to get a better seal on it. But with further inspection, I also noticed that the flange itself was degrading- just losing bits due to rust. I was planning on using some of that QuikSteel stuff to build it up a bit around the edges. But... Would it be in our best interest to remove the heat shield on the manifold to inspect the y-pipe itself? I think it would be. He's arguing with me about it. We've already replaced the resonator and muffler last fall due to them rusting and breaking. Both of those were replaced with Evan Fischer brand parts as well; the boyfriend had the forethought to get the same maker for the cat as he did previously. Thanks for your time. If you need pictures, just let me know and I'll take some. Rachel
- 6 replies
- exhaust manifold
- heat shield
(and 2 more)
Tagged with:
So I'm in the process of revamping my exhaust. I've taken the ASV brackets off of the exhaust manifold, and I'm going to extend my Y-pipes up to the engine itself without the brackets. I took the old crusty gaskets out, and I'm buying new ones. But all of the gaskets that it seems I can order are just simple rings, whereas the ones that I took off were the shape of the pipe flanges on my Y-pipes. My engine is an EA81 on my '83 BRAT. What kind of gaskets do you guys have at this spot? Will the simple, circular ones work? My whole point of working on the exhaust in the first place was to keep it from leaking right at this spot, so I want something that will hold well.
- 21 replies
