Search the Community
Showing results for tags 'expansion valve'.
  • Search By Tags
    • expansion valve ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 3 results
  1. 98 obw 2.2 251k. AC has not worked in years. System has been evacuated and open for a long time. I was going to replace compressor only until I saw black sludge like oil dripping from the compressor and metal bits. Tried to flush all components and it was fruitless. One thing led to another and I fo...
  2. I am replacing compressor on my 95 Impreza. Where is the expansion valve, or is there one? Is there an orifice tube? Thanks.
  3. I am slowly going about converting my '89 RX from R12 to R134a because the pulley bearing on my original compressor failed. I removed the evaporator today and took it apart to get the expansion valve out. The first thing I noticed was some weird rubber/tar gunk around one connection of the expansion...
