Search the Community
Showing results for tags 'field safe mode'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Good Brothers have a problem with my transmission ... now.... no hand held ODB was able to connect to the TCU..... I manually checked the problem by using the power light flashes to determine the trouble code... the code responded was the line pressure duty solenoid... i replaced that solenoid and the same problem arised . i maunally reset the tcu and ECU via battery pole etc...... the same code keep repeating saying it is line pressure duty solenoid. yes the transmission is in field safe mode. now if i start the car... while tumbling just before the engine starts i put it in reverse and the light stabilizes and its out of field safe mode. if i switch off and start back its good... but if i leave it off over 5 mins .. start back the power light continues to flash and transmission is in field safe mode.... what do you professionals think is the problem?
