Search the Community
Showing results for tags 'forester RPM problem'.
  • Search By Tags
    • forester rpm problem ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. Hi, I have a 2004 forester standard, recently when I change gear if I am in neutral the rpm goes high 3000 unless I am in gear and my foot is off the clutch. Also I have an Evap leak check engine light. Any suggestions. I cleaned up the throttle body and the IAC valve and the air filter. I have a...
