Search the Community
Showing results for tags 'forward differential'.
I recently picked up a used transmission for my 2002 L.L. Bean non VDC. The replacement transmission does not have the shaft axle drives coming from the forward differential. Any advice on how to remove the shafts from the toasted transmission and install them in the replacement. Is this procedure p...
My 2002 non-VDC Bean Outback transmission part#31000AE640 has a non-repairable forward diff. I can source a 2002 transmission part#31000AE800 from a Legacy GT. My question is will this work? The parts diagram I referenced shows that it does. Although the diagram for #31000AE640 shows that...
- 3 replies
- forward differential
- front diff
- (and 2 more)
