Search the Community
Showing results for tags 'franken motor'.
Here is another use of the Ej251 with phase 1 Heads (Frankenmotor) in a 1991 Miata called the miataone.com.
- 8 replies
- 1
- conversion
- swap
(and 2 more)
Tagged with:
Does anyone know if you put phase II 2.5 sohc engine heads on a phase I ( 1997) 2.2 liter (using the 2.2 gaskets) will that engine combo work? I need to get a buddy out of a jam in his 2002 OBW by building him the most inexpensive engine i can and I dont have any good 2.5 sohc lower ends that I trust as is. If the 2.2 phase one wont work will the phase one 2.5 lower end work? Thanks
- 9 replies
- franken motor
- 2.2
(and 1 more)
Tagged with:
