Search the Community
Showing results for tags 'front caliper'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. This is a follow up to a thread from last week about replacing a front caliper and recommendations as to used, new, brand, etc. I started out with a garage that told me my front passenger brake was sticking, the cause of our 2003 base model outback 146k miles, pulling to the right. They recommended replacing the caliper, rotor, pads at about $600. I just did a $90 alignment and $550 worth of tires so wasn't in a position to spend another $600. I asked did they check the slide pins, they said yes that's not the issue. I declined and took it home and started looking for answers. I finally after having our garage snowed in, was able to pull the wheel, and examine the caliper today. One slide pin worked fine, the lower one was frozen. It took a pliers and brute force to move. Once out, the good one was lubed, the bad one was bone dry. Next once I got the pads out I found the backs of the pads against the pistons to be very rusted and the insides of the Pistons to be full of rust or dirt or both. One had rust inside, the other looked like a pipe that corroded down to 80% of its capacity. So from here, should I clean the insides with a wire brush maybe on a dremel, or just clean away the loose debri/rust, or replace the caliper. Nowhere locally can I find a rebuild kit that includes new pistons and we have all the major chains. Subaru tells me they discontinued caliper rebuild kits. I bought a new Subaru rotor, and pad set with the hardware. If not for the rust I'd be looking at a simple clean & lube I think. I'm still pretty new to this and not sure I'd be able to rebuild the caliper, if I could find a kit. I'd like to finish this up, today Tuesday the 21st here in eastern PA because I'm working in an unheated garage and it's supposed to get cold again on Wednesday. I've got a bad back & neck, so working in the cold is not good for it. Thank you in advance for any help & advice. Spiney-Dave
