Search the Community
Showing results for tags 'front end'.
Last week, I replaced the CV axles, ball joints, tie rod ends, and struts on my '87 Subaru GL 4WD. For some reason when I apply a lot of (engine) torque when the wheels are turned hard to the left, there's a huge clunk as soon as significant torque is applied. This baffles me, because I've taken it apart to inspect (again) and could find nothing wrong. The CV axles, ball joints, struts, etc., are brand new. The ball joints, strut mounts, hub, axle nuts, brake calipers, sway bar mounts, etc., are tight. I took the wheels off today and re-checked all this stuff. The wheel lug nuts are torqued properly and everything, and I also checked the strut mount screws and the nut that secures the end of the strut into its top mounting plate. The wheel bearings also looked good. They were smooth and tight, and I packed a bunch of grease in there before putting the axles back in. The car makes no weird noises whatsoever when I'm running down the road at 75 mph. It's only when I start a sharp left turn. At this point, I'm standing around scratching my head. Other than the clicking the old axle did (because the outer boot had a rip in it and a bunch of grit got into the CV joint), it didn't make the big CLUNK when I was turning. Anyone have ideas? Thanks!
I have an 82 GL Wagon 4X4 ans since I have owned it it has ran strong but the oil pressure drops to almost nothing when it is idiling for a minute, what could the problem be? Also the front end has started making a kinda rattling/cluncking noise when cruising between 1500-2000 RPM's (4th gear driving 35-40 MPH) my steering boot started leaking a while ago so i am going to replace it this weekend, could it possibly be the tie rod where it connects into the rack? or would it be in the CV axel / transmission connection?
- 5 replies
- oil pressure
- front end
(and 5 more)
Tagged with:
I replaced the front passenger axle on my 88gl 4wd 5spd 115k mi. because the boot was torn and slinging grease all over the engine compartment and on the exhaust. I wasn't having any problems with the axle other wise(no noise, clicking,ticking). So I got a remand from autohouseaz.com and put it in. Checked axle to best of my ability before install and seemed fine, put it in tightened everything up and and took it for a test drive through my neighbor hood. It makes a click/tick noise in sync with wheel speed ONLY while accelerating. It is more noticeable turning right than it is left. Again, it only happens when accelerating. Let off the gas, goes away. Not accelerating and making a turn, no noise. Apply go fast(ish) pedal mid turn, starts clicking. Let off gas, goes away. I jacked up the front passenger wheel and checked for any play side to side/up and down/in and out and everything is tight, no slop. Spin the tire and no grinding or metal on metal sounds. Removed the tire and break/rotor, nothing appeared amiss. Removed castle nut and re-torqued it. Took it for another test, still same issue. After reading through posts here I realize i should have just rebuilt the original Subaru axle seeing how i could have a bunk re-manufactured one. Also I could have wheel bearings starting to go out. I don't feel like wheel bearings could be the culprit only because I wasn't having any problems before replacing the axle. Checked the brakes and they spin just fine, no warpage or anything stuck in it or the tires. My goal is to sell the vehicle because I just inherited a newish truck and do not need her anymore/dont have the room but I do not want to sell it with this issue present. I'm perplexed as to why this only happens under acceleration. Is it possible I didnt get the wheel bearings seated properly? the castle nut is ran up like thge drivers side so I assume they were properly seated. Does any one know where to get an front passenger axle rebuild kit? I would rather do the work myself and know its done right instead risking getting another crap axle. Also where to get the wheel bearings? Thanks in advanced for y'alls responses
- 2 replies
- CV
- Wheel Bearing
(and 3 more)
Tagged with:
