Search the Community
Showing results for tags 'fuel injection'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 3 results
  1. I have an 82 brat I am swapping to Fuel injection using @GeneralDisorder guide. The return line under the intake is 3/16 hose and try as I might I can't figure out how to adapt it to fuel injection hose as FI does not come that small. And the return line from Throttle body is like 5/16. Ideas? Also the throttle cable does not reach the throttle. What have you guys who have done these swaps done in order to fix these issues.
  2. So i recently bought an 87 subi wagon, it had intermittent spaz sessions where it would lurch from low rpm to high. it happened under load most. I think tracked it down to the FI system, most likely electrical... i thought i fixed it with a new rotor and cap as it ran well for about a mile... when it completely stopped getting fuel. My fuel pump is fine. but I tested the FI itself and it its impedance is out of spec. I'm not sure if that can cause it to fail to inject fuel or not, but currently my next move is to get a pick and pull fuel injector that passes the ohms spec from the book. ive got all the pieces of the puzzle except fuel to get her started again. Any of you guys think that the spaz sessions, and the not starting is the same issue? Is there anything i haven't thought of that could be causing this issue? If so which systems would be good to check? Thanks in advance.
  3. So i have a 85 station wagon, its currently got a weber on it. running great. But i recently bought a 87 FI manual trans wagon for 350$... It even runs! besides some serious fuel flow issues i drove it home 15 miles. My question is if i get the FI system working well, which would be better for mpg, FI or a weber? i plan on transplanting the 5 speed trans in either way.
