Search the Community
Showing results for tags 'fuel injector'.
  • Search By Tags
    • fuel injector ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 3 results
  1. Hello, I have a 1992 Legacy Wagon, EJ22, AWD. A few days ago the motor would not fire up and has not fired up since. The wagon has not had any motor work done to it for over 3 years. It ran and drove great over these past 3 years. The wagon has never been in an accident. The timming belt...
  2. Fuel injector cleansing procedure I use: Remove the Fuel injectors. Spray carburetor cleaner Upside down on them, to clean their inlet strainer. Plug a 1.5 feet long Hose, tight on their inlet. Secure it in place with a Clamp. Plug a couple of long wires to their power input, to connect them to...
  3. So my wagon is having issues. Saturday: Ran fine, took out injectors to see if the were the cause of my terrible idle, all seemed well so they went back on. Tried to start it, nothing. A few tries latter the engine seized. I pulled the plugs, unclipped the coil pack, and turned it over. Gas came sh...
