Search the Community
Showing results for tags 'fuel leak'.
	A few months ago I bought my first Subaru in 20 years. It's a 1997 Impreza Outback Sport, manual, royal blue. I love this little car! But it has serious issues, and I'm starting to think I'd be better off walking away from it. I replaced the front brake calipers, some fuel return lines, got new front tires, charged the AC, did a full detail and some serious body work, put on a hitch and wired it for my little trailer. After digging into the car it's now apparent it was flooded at one point. There is dirt everywhere, and rust also. I think it was in freshwater. So, having just learned this after weeks of work, I also found out that the fuel lines are rusted, causing it to drip gas. The drip seems to be inaccessible without pulling the fuel tank, which might be impossible with the undercarriage rust. It doesn't seem to affect mpg much, if at all, but the fumes are intolerable with the windows open. Do I have any options here? It only has 134,000, and runs like a top. The motor and transmission are great. The timing belt was done recently. I've gone through it and everything else looks good. Are there ways to repair rusted fuel lines without dropping the tank? I looked in the fuel line access hatch (which is how we discovered the flood factor), and you can't see the leak through that. Thank you for your help, wise Subie gurus!
	A month ago smelled gas really strong inside my car. Took to the shop and they said the fuel line was leaking in the engine. Prior to taking it into the shop when I tried to start the car it would crank but not turn over until 2-3 tries. Had fuel line replaced. Thought it would solve the cranking but not starting issues but it came back. I was due to have the spark plugs and fuel filter replaced so I did last week. Next day same starting issue. Usually happens after the car has sat for about an hour or two. Cranked but would not start until third try. Just got back from driving it and I see something leaking from around the gas tank. Pretty sure it is leaking fuel. So very frustrated and don't know what could be causing this. What should I have the shop check? Fuel pressure, obviously check leak. Not even sure if the starting issue is related to the fuel leak issue.
	I have 2001 Subaru Outback 2.4L Automatic wagon with about 190K miles. It runs great, however when it gets below 40 degrees farenheit, it has a few symptoms that are not present when the weather is warm. 1. Strong odor of gasoline, so much so that I cannot turn on heat unless the car is moving and wind is forcing the order to leave the engine area. 2. Overheating when driving more than 5-10 miles, regardless of uphill or downhill. At the end of last winter, I replaced the thermostat, drained old coolant, then refilled the system with 50/50 coolant to make sure I had a proper mix. Sure enough, I drove about 10 miles, and immediately saw the engine begin to near the red line. After this, I brought it to a mechanic and asked them to look for any problems and possibly check the water pump. They gave it back to me and told me the water pump wouldn't fail the way it is engineered, and they claimed that it had to be a head gasket problem. I don't believe they actually checked anything out because they didn't charge me after leaving it with them for three days. So, I saved up a little cash and it was around May, when things started to warm up. When I was ready to bring it in to have the head gasket replaced, the weather had consistently risen to 50-70 degreees farenheit and I was no longer having overheating issues. I was testing it on hills, and with AC on full, trying to get it to overheat with no success. So, I figured even if they replaced the head gasket, I couldn't verify that their work was successful until it got cold again, so I didn't do it. Now that we've had a couple weeks where mornings are below 30 degrees, all the symptoms are back, and they seem to be worse when it is really cold than just cold. I don't have anyway of proving that the gas odor and the overheating are related, but I never have one without the other. If I lived in a warmer climate, I don't think I would even be aware that there is an issue because it drives great in the summer and I have no issues, even on long road trips with the car packed and AC on full blast. Other info... I didn't see any excessive rust or metal particles when I flushed the coolant, I've always changed the oil regularly and i've used synthetic oil since it cleared 100K, no major mechanical failures but have replaced starter, alternator, knock sensor, belts when worn. Timing belt changed at 125K. Flushed & changed transmission fluid at 150K. I've regularly replaced spark plugs, spark plug wires, & distributor cap, but I've never replaced the fuel filter or anything fuel related because I was always afraid of a spill and stinking up the garage and having to hear my wife complain for weeks while the smell went away. Please help me!! I've aked every mechanic that I've randomly run into and they only tell me that it's either thermostat, water pump, or head gasket, however none of those suggest that it would work fine in the summer but overheat and stink in the winter. Any insight and explanation could help. I'm at a loss. I don't want to spend $1500 for a head gasket replacement and find out that it was some other anomoly that only costs me $50. I love my Subbie and hope to get her to at least 300K miles.
- 13 replies
- Overheating
 - thermostat
					(and 6 more)
Tagged with:
