Search the Community
Showing results for tags 'fuel pump'.
Everything ive seen about this is all 8+years old with outdated links. Been trying to find a fuel pump, grabbed the f150 inline pump like suggested in loads of other posts on here. I cant find the carter p5000 thats also been named. Owners manual says 36-50psi Pump i got (pfp e16020)...
Hey freaks - I'm looking to source the correct fuel pump for my 96 Legacy Outback. I've searched the forum and haven't found any concrete answers yet. Basically rock auto lists what seems like a few different options and I'm hoping to get pointed to the correct pump. rock auto lists a...
- 11 replies
Vehicle: 1986 Subaru GL Wagon, Dual Range 5 Speed, Carbureted, Weber 32/36 Converted Issue: No longer getting Fuel Pump Signal to the Pump. It would be intermittent, but now seems to be consistent with getting no Signal. I've heard from @Gloyale that the 6 pin Fuel Pump Contr...
Hey guys, I have an ‘87 GL-10 wagon, (Fuel-injected) bought it last month from an owner who garage-kept it. Great little car. My fuel pump started leaking from the little bell on the back of the pump, which I would assume is a pressure relief valve. I’ve been looking for a replacement...
I have an 82 brat I am swapping to Fuel injection using @GeneralDisorder guide. I have everything in place and wired up. My issues are as follows. I am only getting 6 volts at the coil. And I'm not getting any spark. My fuel pump works. But only shoots fuel when it is hard wired. It won't...
3 days ago, my 1995 Subaru Legacy L station wagon conked out while leaving my house. After which, it refused to start up. Just cranks and cranks. Subsequent tests indicate that it is getting spark, but it's not getting fuel. There doesn't seem to be any clicking sound from the relay under the dash w...
My fiance has a '79 Brat that was left to her, and it's having a fueling issue. That is, it was running fine then sat for several years. I put a new battery in it and nothing. If I hot wire the fuel pump it comes on. All I have been able to find is something stating that the alternator sends signal...
Hey all, I just bought an '88 DL Wagon 4WD with a manual transmission. I got a few miles and then the engine just quit. It wants to start, but won't. At first, pumping the gas pedal helped to keep it running for a second or two, but now it's not doing a thing for me. The internet has been comicall...
- 5 replies
- fuel pump
- fuel filter
- (and 3 more)
Hello subaru-gurus, I recently acquired an 86 GL wagon with 230,000 miles. For a few days after I brought it home, on cold starts in the morning it would fire up but idle at a very low RPM. It would stall, and have to be restarted until it seemed to warm-up and then it was fine. Then one day, af...
- 12 replies
- fuel pump
- fuel filter
(and 1 more)
Tagged with:
Hey everyone. 1996 Legacy Wagon L 260k 2000 EJ 251 with EJ25D heads 2000 4.11 5mt I'm having some problems that I'm not sure where to turn to. I have an idling issue. When at operating temperatures, my idle will be low (around 500) but not rough. When the lights are on, and I depress th...
- 15 replies
Attempting to replace the Fuel Filter on a '78 Brat and want to run the fuel out of the line....I took the fuse out from the main breaker (driver's side) labeled "IG ST FUEL" (5th from the top) thinking that would do the trick and disable the Fuel Pump but the car wouldn't run out of gas. This is a...
- 3 replies
- Fuel Filter
- Fuel Pump
(and 1 more)
Tagged with:
Hello all, I have a 2002 WRX and I don't know how i could find out if my ecu is the problem. To start from the beginning, I was trying to find the output of my ECU that could turn it from automatic to manual in the hope of getting rid of p1596 error (automatic tranny diagnosis input signal high...
- 11 replies
OK, First thing that happened is my car would die, almost like a belt broke. Didn't matter how fast I was going, it would just die. I immediately put a new fuel filter on....ran OK for a day. I felt what I thought was "clogs" being dissolved, from the fuel treatment I put in when I replaced the...
- 3 replies
- fuel pump
- fuel system
- (and 6 more)
Fuel pump replacement: Hello all! Question after story time. Context: 1991 silver Subaru Loyale stock 1.8L EA82 5-speed manual trans w/ stick 4WD button wagon w/203,000 miles. I took my kids up into the hills for a great day for July 4th. We went Up and down in the Rocky mountains and...
- 15 replies
- 1
My 86 Brat broke down a few weeks ago & had it towed home. It turns over fine, but will not start. A few details: It had run out of gas completely a few weeks earlier. Could the debris/sediment in the tank have gotten "concentrated" because of the low fuel level and the fuel lines became clogged?...
I have a 99 Subaru Forester and I've noticed a squealing noise from the tank. I am sure it's the fuel pump, my question is about replacement should I get a Subaru pump or are aftermarket pumps ok. How difficult is taking the tank down? And is there anything I should know before taking on the repair...
Hey, so I've tried searching all around to fix my current issue with my fuel pump not running. The engine cranks over but its not getting any fuel due to the fuel pump not starting. I've pulled the fuel pump out and tested that it's working. Checked the relay and I am pretty sure that its working...
I have a 91 Legacy wagon which constantly has issues with starting. Normally if it has been sitting for a few hours without being driven then it will start up just fine, but if I drive it somewhere and then turn it off and try starting it again shortly afterwards, it will not stay started. The only...
I have a 91 Subaru Legacy and it will not stay started when I start it unless it has been sitting for awhile, for example overnight. But if for instance I drive to the store and then shut off the engine and go inside and then come back out and try to start it again, then it will not stay started whe...
- 6 replies
- subaru legacy issues staring
- subaru
- (and 7 more)
I have a 91 Legacy wagon which has been having startup issues on occasion. I usually manage to get it started by attempting to start it with my foot on the gas pedal, but when it starts it usually sputters for awhile and often turns off again. When I just turn the key in the ignition prior to starti...
Howdy, My Subaru won't start all of a sudden. I am new to this car, so bear with me. I will explain what I have observed. Upon turning the key to a point the lights turn on the fuel pump in the rear makes a "Rrrrrrr... Rrrrrrr" Sound with about a one-and-a-half second pause between sounds. This...
Hi all, I'm new to the forum. I have a 2000 Outback wagon that I was keeping a year for my son (out of the Country) that I would start every couple of weeks. It ran well, until I parked in front of the house for a couple of weeks, then it wouldn't start. The gas cap wasn't messed with, so I don't...
- 10 replies
- wont start
- fuel pump
(and 1 more)
Tagged with:
