Search the Community
Showing results for tags 'fuel pump relay'.
It's not the 16 flashes after start up indicating a fault code. When driving for a while, it will start flashing continuously. Engine Temp is fine, normal driving no shifting issues. Turn the car off and start it again and the AT TEMP is back to normal. Helping a fellow here in Colorado Springs. Thoughts? Thanks, Larry
3 days ago, my 1995 Subaru Legacy L station wagon conked out while leaving my house. After which, it refused to start up. Just cranks and cranks. Subsequent tests indicate that it is getting spark, but it's not getting fuel. There doesn't seem to be any clicking sound from the relay under the dash when turning the key. Also, no sound from the pump (I removed the outer cover, so I could hear it better). I suspect the relay has gone bad after 220k miles. But it could also be the pump (among other things, as always). I want to test the pump to see if it will run without going through the relay. I've read lots of things about hot-wiring pumps with a jumper wire between the battery and one of the wires going into the fuel pump. But I'm just not finding anything that says/shows exactly WHICH wire that might be and WHERE exactly it's located. Like it's common knowledge or something. But it's not to me. I'm not a real mechanic. I just pretend to be one, when necessary. Surely, somebody can tell me how to do this as easily as possible. Preferably without getting into electrical jargon that boggles my mind. Any help greatly appreciated, as always.
Hey all, I just bought an '88 DL Wagon 4WD with a manual transmission. I got a few miles and then the engine just quit. It wants to start, but won't. At first, pumping the gas pedal helped to keep it running for a second or two, but now it's not doing a thing for me. The internet has been comically unhelpful, for example: I haven't found reliable information regarding the location of the fuel pump. Is it in the tank, or under the passenger side rear seat? What's the best way to approach it, through the trunk or from underneath? Any and all help, insights, pictures and advice are much appreciated.
- 5 replies
- fuel pump
- fuel filter
- (and 3 more)
Hi Everyone, Just got a 1982 GL Wagon for $175, this was a nostalgia buy, as my parents drove me around as a kid in this car in the 80's/90's. The guy I bought it from said it needed a new fuel pump, I took him at his word and put a new one in, the fuel pump is not getting current. I traced the wire from the pump all the way to this funky relay (that's a total guess) that I can't find ANYTHING about online. Help!? Just need to get the engine fuel and I think it's ready to go. The previous owner did seem to tear the stereo out and there are quite a few loose wires about. Is there any in-line fuses I'm missing or is this not a relay at all?
- 2 replies
- fuel pump
- fuel pump relay
(and 1 more)
Tagged with:
I am attempting a compression test on my 99 Legacy Outback. Only thing I need to figure out before getting started is: Where is the fuse or relay to disconnect my fuel pump? Unfortunately I don't have the Haynes manual for my vehicle. I've searched these forums and online, and been digging around my vehicle, and can't seem to find it. Hoping someone here knows. It isn't in the fuse box behind the battery, nor in the driver's side interior fuse box beneath the dash. No mention of it in the user's manual. I asked a clerk at Advance Auto who owns and works on a 2000 Subaru sedan, and she wasn't able to find it either. On hers, it was in the fuse box behind battery. Sorry for the newbie question; hopefully someone can help! Thanks.
