Search the Community
Showing results for tags 'fuel system'.
Hello! My ‘81 Brat GL 1800 has a vapor separator behind the passenger seat behind the bed panel. Mine is crumbling and is now fused together with epoxy. Hurray! I’m looking for a “new” one or I’m curious if there is part interchangeability with another car. It is listed as subaru part number “6420571001” or “642057100” Shown as Detail “O” in diagram. Thank you! My Brat thanks you. The environment thanks you!
OK, First thing that happened is my car would die, almost like a belt broke. Didn't matter how fast I was going, it would just die. I immediately put a new fuel filter on....ran OK for a day. I felt what I thought was "clogs" being dissolved, from the fuel treatment I put in when I replaced the fuel filter. However, the next day it started dieing again. Than it died and would not start again. I replaced the fuel filter again, and the fuel pump. I can hear the pump start to work, or at least think I can. Plan on seeing if starter fluid will start her tomorrow...and hoping like hell I can find the relay....Please any advise is soooo very appreciated!!!! I'm on a super tight budget and my kids have sports, I am definitely up sht creek with out a paddle...plus my car is at a gas station parking lot......
- 3 replies
- fuel pump
- fuel system
- (and 6 more)
Hey guys, I'm new to the forum as ya'll can see. My family has a couple of '96 Subaru's so I figured joining this forum would be a good idea. So I've got a question. My 1996 Subaru Legacy Wagon GT has had some problems starting up after it's been running for awhile. It never does this when it first starts, only after it has been run earlier and then stopped. My dad and I just replaced the entire exhaust system and both cats, and got the check engine lights to come off that had been on since I got the car almost a year ago. We've also pulled the motor and replaced the the rear main seal where it was leaking oil and put it back in time before putting it back in; however, it still has this occasional startup problem. When it happens, I have to give it gas to turn it over and afterwards it putts and acts like it's going to die before it starts running normal again. Could this be something to do with a vacuum line? Just wondering if anyone else has experienced a similar problem. Thanks, Dan
- 5 replies
- fuel system
- gas
(and 1 more)
Tagged with:
