Search the Community
Showing results for tags 'fuel tank'.
  • Search By Tags
    • fuel tank ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 5 results
  1. I have an 86 BRAT that has a leaky fuel tank. Now as many of you probably know you can't get new tanks for these. I've cleaned it up and repaired it about 90% of the way, I used some sheet metal and solder. However my solder joints leak in a couple places and refuse to seal. Does anyone know if some...
  2. Hi all, EJ251 block/EJ25D heads in '98 OBW, 5MT Recent work done in the past year: Plugs (ngk) wires (ngk) Timing belt kit (oem) Timing cam gears (oem) Cleaned and swapped out IACV Swapped out MAF Swapped out TPS New Fuel Pump, Strainer, Fi...
  3. I cannot add gas to a 2009 Impreza (with around 65,000 miles). I have seen dozens of complaints about this issue on different message boards, and of the 41 complaints on the NHTSA site about this vehicle, 5 of them are about this same issue. When I attempt to pump gas (with the tank less than 1/...
  4. Hi everyone, I'm in the UK where the L-Series was never massively popular but I've had 4 over the years and I'm doing a rolling restoration on my old red one. The last MOT for my 1992 l-series estate was ok but for a leaking petrol tank. I dropped the tank out of the car, decanted the fuel, wash...
  5. Hi all, My trusty 1992 UK spec 1.8 L-series 4x4 Estate failed it's MOT last week due to a leaking petrol tank. I've removed the tank today and have found very small leaks in the rear seam and, in addition, two of the outlet pipes sheared off when I disconected their rubber pipes - they were real...
