Search the Community
Showing results for tags 'gear oil'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. This may have been covered before and I just missed it, so if I did someone please just point me in the right direction... but I have been searching the forms for the past two hours and have come up with not a lot. So anyways, I was wondering what everyones favorite gear oils/lubes are for the EA81 4 speed trannys. So far it looks like Amsoil is a good choice from what I have read. I was hoping to be able to find something a little cheaper that I can get off the shelf that would work nearly as well. I know JesZek loves Motul 80W-90, but from what I have found online that stuff is insanely expensive for my thin wallet. Although Im sure it works like wonders. Has anyone tried Royal Purpel's 75W-90 synchromax? I know its just about as spendy as Amsoil, but I am curious if anyone has any experience with it so we can compare. Right now I am running the walmart supertech 75W-90 and i want to get something a little higher quality in there so I can make this little tranny last.. and shift easier in the winter months 5-speeders are more than welcome to give their experience as well! As so far it looks like they take the same oil/lube as the 4spds...
  2. I have a 2012 Subaru Impreza 2.0i Sport Limited (automatic CVT) that I am having some problems with the front differential. A little background… I was driving fairly aggressive for 1-2 hours and the “AT Temp” light came on. I the slowed the vehicle exited at the next exit (~8 km) and turned it off to cool. The next day I was driving about 70 mph (~110 km/h) when the vehicle had a sudden jerk and vibrated aggressively. The rpms dropped to ~2000 and would not go higher. I pulled over and smelt something burning. The vehicle now makes a grinding clunking sound under the car when putting the foot on the accelerator. It sounds almost like loose grinding wheel bearings and is coming from the diff/transmission area. At first I thought it was the CVT... But I drained the CVT fluid and there were no signs of metal debris and color looked good. I then drained the front differential and there was fine metal debris on the magnet. I put new fluid in and drove the vehicle 25 miles (~40 km). The sound diminished some, but is still there. I drained the fluid again and it was littered with superfine metal flakes smaller then glitter. I found one piece of metal as thin as a razor blade and about 8mm x 3mm attached to the magnet. I planned on selling the vehicle this month prior to the mishap... so I’m trying to determine my options. My brother is a mechanic and we can do the work. The problem is we can’t find a front differential. It seems that everyone wants to sell the differential with the transmission. My question(s) to the forum are: Does this sound like the front differential needs to be completely replaced? Or is it perhaps an easier repair? If replacement its needed… does the transmission also need to be replaced or can a guy just do the diff? Can any more harm be done if I keep driving the vehicle and ignoring the sound it makes? What are the consequences? Much appreciated!!
