Search the Community
Showing results for tags 'gear ratio'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 4 results
  1. My transmission is TY752VACAA the donor trans is TY752VA5AA. Both have exactly the same gear ratios ,except for 5th. Mine is .780 the donor is .825. what if any issues might I have, without swapping the rear diff or driveshaft. The Impreza that Im getting the trans from was originally an automatic. Someone had done a manual swap on it, I checked the vin decoder. The donor has a 1.8l ej18 engine in it now. I have a 2.2l ej22. I’m unsure of the rear diff on that (donor vehicle )if it was swapped when the manual was put in. But with all the gearing the same other than 5th, should I be good with just swapping the transmission?
  2. I'm new here and new to Subarus. I have a 1997 Legacy Outback 2.5 automatic AWD, and I think it needs a new transmission. The model number on the bell housing is tz102z2cba-dt. I've found a japanese import transmission that I'm told will work, model number tz102z1caa-dg apparently from a 1998 Outback. Does anyone know if this is correct? I'm looking for a direct replacement, if possible, and I'm having some difficulty finding these model numbers online to really compare them. Any help would be greatly appreciated.
  3. I recently picked up a 97 Legacy GT sedan to use as my work car. I purchased the car knowing the transmission was in bad shape and would need a rebuild or replacement. I removed the transmission this week and had plans to swap in a 98 Outback transmission. I inspected the ring and pinion on both and determined the transmission in the GT which the PO advised was a low mileage JDM swap had a 4.111 ratio. The Outback transmission had the correct 4.444 ratio that should be in all of the 4eat 97-98 2.5 powered cars. I have searched the forums and not been able to find decoding information for rear axle ratios. I was only able to find a small sticker on the back of the rear differential housing with "T2" on it. does this indicate the gear ratio? If so, what is the ratio? My theory is the PO swapped out the original transmission with a transmission with the wrong ratio and damaged the transmission due to the incorrect ratio. The engine and transmission that were in the GT when I bought it were JDM swap according to the PO. He did not have the paperwork on the JDM engine or transmission. Both looked really clean, however the transmission is noisy and the PO said it slips at highway speed. The fluid smells burnt. To reiterate, I need to know how to tell the rear differential ratio so I match up the front differential correctly when I put a transmission back in. I know it should be 4.444, but since other things have been swapped and there is no paperwork for those items, I don't feel comfortable assuming it is still the original rear. I am starting to have suspicions this car may have been a 5MT car to start with. I'm guessing that information would be in the VIN somewhere. Can someone tell me where that is in the VIN?
  4. Happy Thursday. No problems involved with this thread. Simply trying to identify where the rear diff. came from on my GL. Correct me if it's stock... I don't believe it is. '87 GL Wagon - converted to AWD. Stock hub drilled to 6-lug. Rear diff p# 722011002 Gear ratio - 4.111 Now, which differential w/ that part number and ratio out of the bag, would work with the original hubs of the GL? Pics if requested.
