Search the Community
Showing results for tags 'gen 3'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. I’m picking up a gen 3 Loyale wagon 5spd 4wd. 375k on the chasis and 150k motor from a wrecked 2WD. It’s been driven daily by the owner for the past month since the motor swap. My plan is to get it ready and reliable for driving up Mt Hood and snow this winter. I mean it already sounds decently reliable while the guy’s been taking it down logging roads solo. But I’d rather work on things now while the weather’s decent to work outside and the lifts aren’t running. I’ve never had a vehicle at this mileage before. Seems a lot of things can wear out in 375k miles. What are some good preemptive measures and maintenance to should take care of? What are some things that could shockingly live forever without touching? Maintenance that’s likely to have happened by 375k? (Not that there’s any way of really knowing) Leaks some oil but seems fine if it stays topped up. How concerned should I be about the head gasket? Motor is only at 150k. Power steering is out but still drives okay. After reading some threads it sounds like some people just drive it and don’t bother fixing. Probably want to avoid any Austin Powers parking scenarios. The struts could be better. It looks like replacing them with stock KYB will raise the rear end. Any remedy here? Or it’s a non issue? Not too worried if that’s an advantage when loaded down. Otherwise it starts, handles, and stops fine. Should I replace springs? Seems like that isn’t a common thing to do around here The A/C works so that should take care of defrosting. Even the rear window defrost works. The heater functions but could be better. The 4WD works. Love the light up display when you hit that Fire Torpedos button! Has (used) snow tires on it already. Debating on buying newer snow tires or all terrains. Eventually I want to do a 2” lift, auxiliary battery, extra lighting. That is, if it doesn’t blow up before I can get to any of that. Priority is to get the thing reliable for the mountain. I have tools but haven’t done any serious car work in a long while and only worked on motorcycles for the past few years. I’m capable but compared to bikes I have a feeling this thing will be more ...involved. So what should I get to work on?
