Search the Community
Showing results for tags 'gen2 outback'.
2003 Outback H6 Taking a little road trip to the hill country next month. I rotated tires today. Took the opportunity to inspect around and try to get a little lube in the sway bar bushings - hoping to help an occasional 'groaning sound' from the rear when maneuvering/bouncing the car. some good news, some bad; tires evenly worn Centric PQ ceramic brake pads really last! So do OEM rotors. rear diff mount bushings look good, rear axle boots and everything back there actually looks OK to good. One or 2 suspension arm bushings look 'off-center/worn'. One of those could be source of noise I guess? No movement on rear wheel bearing up-down - side to side rocking test. No oil on top of (replaced, not original) struts. some wetness on the charcoal box ? - and, now I think, there may have been some wetness under the car from around there - will investigate further if it smells like fuel - haven't noticed that and it seems it would be quite strong in the garage if even a little gas were there??? Both sides of the front have about 2-3mm of 3-9 o'clock movement at the wheels(tires on) - appears to be inner tire rods. No apparent problems felt inside or tire wear but, I will put that on the 'to-do' list for this fall or more likely next spring. One front bearing test moved about 1mm up-down. I may let that wait...can't decide. If I diy that, everything I've read leads me to believe I should tackle it one of 2 ways - on the car with some 'hub tamer' type of device, or take the knuckle to a dealer/shop. thoughts? Still looks like the oil cooler adapter is weeping, not enough to spot the ground yet....I have read mixed reviews on success at swapping that seal so, I'm gonna wait. a front outer axle boot is ripped so, need to deal with that. I THINK I have an OEM spare axle, if not, I'll try to find a used one, reboot the inner and swap. No clicking yet so, I'm gonna let it wait too.Since it's the outer, an interesting experiment might be to try knocking the Rzeppa joint off and installing a new aftermarket one on my OEM axle...might do that and hold the axle in reserve for the other side or ??? for the money/hassle, used entire half-axle is still probably better. glanced at resevoirs and checked the oil. likely do that again before the trip.
