Search the Community
Showing results for tags 'group n'.
I was considering forking out $$$ once again for a group N (STI) transmission mount for the Legacy, as I bought one a few years ago and fitted it to the Forester with very happy results. Then I found the remains of the windshield adhesive sealant I had recently used to toughen up the Vivio’s failing engine mounts, and I then dug out the Forester’s old soft transmission mount, still in one piece... ....So I am experimenting with... One original Forester SF trans mount, Two unused hard rubber bushes from a Fiat Panda’s trailing arms, 1/2 tube of windshield adhesive/sealant. - -Thoroughly clean and degrease the mount, and force in the bushes (bench vise did the trick): -Tape up one side to prevent seepage: -Squeeze in sealant from the open side as thoroughly as possible: -Do what you will with the excess, and leave to cure for a few weeks: When it is cured I shall remove the Legacy’s existing mount and compare them both in the hand, before fitting and coming back with an update. I am expecting a firmer mount, though not as stiff as the real STI component.
- 8 replies
- bushing
- transmission
(and 1 more)
Tagged with:
Hey guys, I am looking to replace my engine mounts while the engine is removed for re-sealing. Stock XT6 mounts are long NLA, but I have seen some references to using Group N mounts. Can anyone confirm for me which ones work and if they are plug-and-play? I had a Group N transmission mount in my '03 Legacy and loved it. If I can use the Group N trans and motor mounts in my XT6, a link to specific part numbers / models to use would be appreciated. Thanks, Jeff
- 8 replies
- engine mounts
- motor mounts
(and 3 more)
Tagged with:
