Hi!
I replaced timing belt and idlers in Subaru Impreza 1996 (ej20), removed pin from belt tensioner to tighten belt and after that rotated crankshaft pulley few times by hand. I was looking to see timing marks in pulleys and white lines in belt to get aligned again but it didn't happen so I turned crankshaft maybe 20 more times. They still didn't align so I asked someone with more experience about the situation. His opinion was the marks should align so I figured that belt slipped when tensioner pin was removed causing this confusion. So this evening I reinstalled belt paying attention that marks were ok in sprockets and belt and rotated crankshafk few times. Same result: when camshafts and crankshaft hashmarks were up the white lines in timing belt weren't. I'm starting to think they even shouln't realign but please verify if that's the case and if they should align what to check next as I'm running out of ideas with this. Thanks for help =)
