Search the Community
Showing results for tags 'head gasket water pump'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. My 02 OBW has 138K on it. Found the Temp needle sky high ten minutes into a drive. Added some water and noticed that if I kept the RPMs up above 3000 the temp stayed down and heat worked. Once I get the RPM down around 2000, the heat cuts off and temp goes up. I thought this means the water pump is bad. But I found out from my stealership friend that the OEM water pumps never fail moving some water. I checked and it looks like I get the bubbles in the coolant when I rev it up from a cold start. And one cylinder is not firing at idle. So is it the dreaded HG issue? thanks mike
