Search the Community
Showing results for tags 'heating and cooling'.
  • Search By Tags
    • heating and cooling ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. So I had replaced the thermostat the first time and a couple of months later it was overheating again- usually after it had been running off and on that day. short 10-20 minute trips. doing fine, then temp gauge shoots up and it doesnt come down till I turn it off. The heat might not work as well....
  2. My timing belt broke a while back as I was just leaving for work. I rolled the car back into a wide spot in the driveway until I could get parts and the time to do the job. Well, that was about a month. After getting the job all done, I fired up the rig, turned on the heater and was covered in all m...
