Search the Community
Showing results for tags 'high beams'.
so ive been chasing my tail on this brat ive been working on. it has no turn signals, high beams, or hazards. intermittently the hazards will flash out of nowhere, even with the ignition off, and the key out of the ignition. the indicator for the high beams lights up on the dash, but the headlights don't work, the low beams do however, I can also hear a relay click when I turn on the switch for the high beams. there are no turn signals at all. there is a silver either relay or flasher on the drivers side behind the dash that gets extremely hot, does not click or anything. and it looks like theres a spot for another, but there is nothing plugged into it. also, I am having a bear of a time finding a Cyclops switch. PLEASE HELP!!!!
- 2 replies
- turn signals
- high beams
(and 2 more)
Tagged with:
I have a 2006 Outback that recently had alternator problems. I have had the alternator rebuilt (the regulator was bad) and re-installed it. All of my issues have been corrected with the following exceptions. 1) my high beams do not work, either pushing the switch forward or just trying to flash them 2) my fog lamps do not work, when you turn the switch to turn them on the high beam indicator on the dash illuminates but the lamps do not come on. The headlights and running lights work fine. My first Subaru, love the car but it is turning into a money pit. Thanks for all help and suggestions.
- 4 replies
- fog lamps
- high beams
(and 1 more)
Tagged with:
