Search the Community
Showing results for tags 'hitachi 2bbl'.
  • Search By Tags
    • hitachi 2bbl ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. I am new to Subaru and have acquired an 83 GL station wagon, straight body, garage kept and she runs!...kinda. It starts but floods because my metering rod is seized inside the carter weber carb. I seem to have purchased the last rebuild kit in the US (or so I've been told) for just about $300!...
  2. Hi! My Subaru Loyale stw, 1987, 4x4, 1.8L with Hitachi 2 bbl carb didn't pass inspection, inspector said it was running too rich. I had rebuild carb partually earlier, replaced accelerator pump and gaskets and cleaned it with carb cleaner, after that flat spot was gone. Ignition timing is set to 8 d...
