Search the Community
Showing results for tags 'horn relay'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. So I am posting this here in the hopes that it will be easier for someone else to solve the problem I just had. It took me way more googling than I would have expected. So, my horn would not sound even though when I pressed the horn (airbag) I was getting 11 or so Volts at the wires (13 or so if the engine was running). And when I jumped the horn directly to the battery (the horn's black grounding wire had to be connected) it would sound. It was driving me nuts. Finally figured out that it might be the horn relay, which is conveniently (not!) tucked behind the fuse box, under the driver side dash, on the left. You will have to remove the lower dash (easy) to get to it. Even though the relay would click and click and click when pressing the airbag, it was still bad. I swapped it out and voila, the horn works again. Here is the best description/pictures I could find of the relay location. It's red with 3 orangish-red wires going to it. Mine was tucked behind the fuse box and I gently pulled on the relay to get it loose and then fished it out. Hope this helps.
