Search the Community
Showing results for tags 'idle air control valve'.
Hi all, My CEL went on the other day when I started my Subaru Outback 2011. My engine had a minor backfire and since then the idle has been on the fritz, going up and down with out and pressure on the gas pedal. From my research it seems like the idle control air valve. Can anyone verify this for me and recommend the best place to get a replacement part? Also, if anyone could point me in the right direction to locating the idle controls air valve in my current engine that would be awesome!
I recently replaced an idle air control valve and the check engine light is still on and the idle is still rough. Do I need to reset the ecu? Or do I have a faulty wire? I'm a bit unsure because normally I've never had to reset the ecu.
- 11 replies
- 1
- Check Engine Light
- Idle Issue
- (and 3 more)
Hey ya'll while taking apart my IAC I partially broke the gasket (it's useable, but super hard and now part of it is missing). I was curious 1) if it's supposed to be a non-flexible plastic or if mine is just really old. 2) Could I use a gasket maker to make a new gasket for it? I'd rather not go through the trouble of ordering a new gasket and waiting around for it to show it. would be awesome to grab some RED RTV and just do it today. Not sure about gasket maker cause I've never used it before. I've been reading on here, but couldn't find any solid info. Let me know what ya think or if gasket maker would be okay which one ya'll could recommend. Also! check out that new prof pic. GAMES GAMES vinyl on the GL now for free via school....
- 3 replies
- idle air control valve
- diy
(and 2 more)
Tagged with:
Hi everyone - I'm new here. I have been having ongoing problems starting my 1992 Loyale and it has been diagnosed as needing to have replaced the idle air control valve and/or the throttle position sensor. The repair shop has notified me that they are having trouble finding the parts anywhere. Does anyone know where we might be able to locate them?
HERE IS WHAT HAPPENED. Yesterday, I discovered the green connector for CEL testing has been plugged in forever. i unplugged it, and proceeded to do what I know, in order to read the check engine light. The oxygen monitor showed codes 21(coolant temp sensor), 24(idle air control valve or circuit) and 34(EGR solenoid or circuit). It got dark, so I went inside and proceeded to look online for a replacement IACV gasket, so I can clean it. I also looked at an EGR solenoid and planned on cleaning the EGR today. When I went to start my car this morning, it fired but died immediately, and I knew something was wrong. One more start and die, and without pumping the throttle or having it wide open, the car just cranked and didnt fire. What the heck? So I read the codes again, and nothing had changed. As far as I know the only thing I did was make a red light blink, so i'm a little confused. Is it possible that the car is acting up because the ECU "didnt know" about the bad egr and iacv until i put it in test mode? before having gone inside last night i started the car, and it RAN FINE. Again, what the heck? Does anyone have any ideas? car has always had idle issues, and at one point an ignition coil that arced to the negative ground. ask me questions and i will answer, but so far, thats what i got. Thank you guys in advance. -walker
