Search the Community
Showing results for tags 'ignition lock'.
I am searching for an exploded view of a tilt ignition lock for a 1984 GL wagon. Trying to locate retaining pin but cannot find. Another post suggested first removing the band that indicates switch position, I did. Then suggested, at 5 o'clock position for pin/screw hole, no hole or solder plug I can find.
I need to replace the entire ignition lock assembly on our 2000 Legacy Outback due to a problem making electrical contact to start the vehicle. All of the Subaru specific videos I saw on YouTube only address replacing the cylinder. Does anyone know if there is any good tutorial out there and any specific tools I might need over the ordinary tool-box tools? Thank-You for your time and consideration!!!
- 24 replies
Does anyone know if a 1987 brat (brumby) ignition lock assembly will fit a 1991 brat (brumby) or where and if a 1991 lock assembly can be purchased thanks ARJ
