Search the Community
Showing results for tags 'ignition module'.
Hi, For months I've had trouble trying to get my '92 Subaru Loyale started. It shut off back in February, couldn't start it again for days. A mechanic said the timing had slipped, he fixed everything, put in new distributor, timing belts, a few new hoses, new coil. But it still gave him trouble starting up. He could fire it once and it ran good, but cut it off and try to start it again and it wouldn't work. Next he did some kind of coil bypass and said the problem is that the power transistor/ignition module was getting hot and needed to be replaced, which explained why he said I wouldn't be able to start the car again until about 5 to 10 minutes after it ran because the transistor/module was too hot. He also said my starter was going and that I should work on getting that replaced. He didn't want to go any further and pay for that or the ignition module, so left it to me. So the car did run great like he said, but I still had the problem of having to wait 5 to 10 minutes to start it again each time. Then one night my car made a weird sound under the hood on the road and it slowly started coming to a stop, check engine light was on. Wouldn't crank even after I gave it time to cool. Then after about an hour it started up and I got back on the road but it died down again. Had to get it towed back to my area. After that I got the new starter put in and it started up fine but again the engine died after some minutes. Then recently I finally got that new ignition module put in and also came with a genuine Subaru coil. It started up after a friend of mine who works on cars charged the battery, and it ran great. We let it run for about 10 minutes to get the kinks all out after months of not running. Then we cut it off and tried to crank it again and it wouldn't start. I chalked the problem up to be that the mechanic who fixed my car the first time messed something up with the coil, doing some kind of bypass, but now I'm puzzled as to what could really be going on. Every time I get a jump to the battery the car will start up just fine, but then cut it off and try to start it again and it won't run. Really weird. Me and my friend also noticed that when he kind of touched the wires to the ignition module connector while I tried to crank engine that it roared to life, yet it will also start up when you charge the battery. I really don't get what's going on. Not sure if the issue is that I need a new ignition module connector, or a new battery. Can anybody help me?
- 16 replies
- loyale
- ignition module
(and 1 more)
Tagged with:
The Ignition Module is the Electronic Part that Substituted the Points inside the Distribuitor; it usually consist in two parts: One Pick up the Signal and the other sends the Pulses to the Ignition Coil. How you Test an Ignition Module? This Test was Done with the Nippon Denso Distribuitor, from a Carburated EA82 Subaru Engine, from the 2WD version; but this test is pretty Standard. This is the Nippon Denso Distribuitor, without its Cap, so you can see its Interior: The Red Part is the Rotor, while the Two Black plastic covers under it, hides the Two Parts that conforms the Ignition Module, they only have two Wires Between them and other two wires that goes outside from one of them, to the Ignition Coil. To do the Test, You'll Need: - A Good 12V Battery and Jumper Wires to use its Power. - The Distribuitor with its Rotor & Ignition Module inside. - The Ignition Coil. - A Sparkplug's Wire. - A Sparkplug. The Distribuitor has two Wires that comes from the Ignition Module, one is Black with White Stripe, this is the Positive (+) while the Yellow one is the Ground (-) or Negative one. The Easy Test Procedure goes as Follows: If you Turn Manually the Distribuitor's Gear under it, Two things Might Happens: ► Sparks on the Sparkplug = Means a Good Ignition Module. ► No Sparks on the Sparkplug = Means a Dead Ignition Module. But you MUST Double Check that you have done Right the Connections. I Hope this can Help. Kind Regards.
- 1 reply
- 3
- Loyale 2.7 Turbo
- Loyale
(and 6 more)
Tagged with:
