Ok I will try to keep this simple.
I have set my timing,new plugs got spark on test, checked all cylenders #3 when spark wired pull does nothing to Idle others idle down. pulled injectore from 3 and one beside swaped injectors retest same results #3 still does not idle down others Idle down still. Is this now a wire problem to the main brain or fuse, Something like that? I am at a lost, if so what needs to be done and how. Thank you all.
My name is Robert I am new here, it is very nice to meet you all. I do have some knowlege of my Forester fuel pump,timing belt and timing set,radiater, altenator,air flow. if you need help
