Search the Community
Showing results for tags 'intake manifold'.
  • Search By Tags
    • intake manifold ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 4 results
  1. I am looking for a 2 barrel intake manifold and carburetor for my 82 Brat. I rebuilt the original one barrel with a fualty kit, bad acelator pump. I would like to switch to the 2 barrel. Are there any 2 barrel adaptors for a one barrel manifold or a different one barrel carb I could subsitute....
  2. I am replacing seals on the intake manifold of my 1992 Loyale with 187000 miles. The surface around the water passage is covered with some stuff that is hard to remove. What is it? Is it possible that they leveled the surface at the factory? Do you guys coat the new seal with something? R...
  3. OKAY, I knew my intake was a little warped when I put it on,so I used two gaskets on each side and Indian Head shellac............AND.............IT leaked....I have decided to fix it,so I took it off and have two options since I cant find one anywhere (My local Knoxville Tn Pull a part has non...
  4. Greetings, This time I am trying to do my Best to help a Friend, Mr. Mariano, who owns a 1980 Subaru GFT-5 Coupé, which came factory with an EA71 engine that features Twin Hitachi carburator setup. Here is a Photo of his Subie: Here's a Photo of that Subie's Engine Bay...
