Search the Community
Showing results for tags 'intermitent idle speed sensor'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. My 87 EA82 3AT wagon began doing odd things a while back. Occasionally, when idling, the engine would rev for a fraction of a second. Once in a while, when cold starting, it would fire initially, and die. Cranking with the pedal half way down or so would get it to re fire, and run rough for a few seconds, then be normal. These things began roughly around the same time, and fairly infrequently, like once per week, so trouble shooting would have been near impossible. As I expected, the frequency of these occurrences increased. The last few days, the idle would almost always be 1000 -1500RPM. So I put an ohm meter on the thermometer - the temperature sensor that the ECU uses, not the one for the temperature gauge. The sensor in question is on the lower part of the thermostat housing, toward the front of the engine. It has 2 wires connecting it to the harness. And it read jumpy numbers in the low thousands of ohms, from when the engine was hot, all the way down to room temp. Put in another sensor, poof! Works fine now. Posted on the chance that someone may have the same mysterious trouble someday.
