Search the Community
Showing results for tags 'knock sensor code'.
  • Search By Tags
    • knock sensor code ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. I am completely lost... went to Advance and had it put on the computer and was told it was an O2 sensor, changed, pulling out and push the gas and pull out at 5mph regardless of how much gas I give it. Suspected throttle position sensor since Advance now says they can't check the codes cause it was...
