Search the Community
Showing results for tags 'l series'.
@Uberoo - going on from protontodd’s thread: you asked me about strengthening the L chassis after I made some comments about this. Below is what was shared with me. That’s all I’ve got and it’s not great quality in terms of sharp detail. Hopefully that gives you an idea of what was done for the rally vehicle setup Apologies for the delay in digging this up. It’s been in the back of my mind for a long time! Cheers Bennie
- 2
- l series
- l series body strengthening
- (and 3 more)
I thought it time to share my full L series build - I had a thread in the welcome forum, but since writing this out recently I thought it a good time to move over here. Some of you will already know this vehicle... This is the short version I purchased Ruby Scoo from Yackandandah, VIC, Australia (google it!) in 2004 or 2005 for $500. What we didn't know was that the engine was toast - over heated to the point that one cylinder was cracked about halfway down. After some research I found that the EA82 engine came in EFI format, so went with one of these and had a steep learning curve into the operations of EFI systems. Pick a part became my best friend here! Problem was I lived over 1 hour away. After a year in the shed she was ready for rego. This is me learning some 4wd'n with a mate near Kangaroo Flat, Bendigo: From here I had a few mods done - welded rear diff. This was a good and bad mod as it gave the vehicle awesome point and shoot abilities but with the lack of lift I managed some damage to the underside of the body, I inverted my floor pans and didn't realise this for some time. In 2007 I roadtripped to WA with my brother with a "fresh" 9 month old rebuild that was going really well: SA/WA boarder: Perth: Hit a new milestone while I was there: And we had some fun too: On the way home we (read: my brother!) blew the side out of the plastic radiator end tank on a hot day drive home. We were stuck in Tintanara and were trucked home the next day. After sorting a temporary radiator it turned out that the engine was severely cooked. For 18 months I put up with a jerry-rigged carb engine over the MPFI wiring. It got me around while I sorted all the bits for my EJ22 conversion - again pick a part played a huge role in this conversion - this time I got all the bits I needed the before getting into the conversion. Cutting down the wiring was another steep learning curve and in hindsight quite easy to do, just need to know what you actually need and go from there. I didn't do the HG's on the EJ as I bench tested the engine and was happy with how it operated. When pulled from the yard it had 127xxxkms on the clock. Turned out the clutch was completely fried. All oil seals were replaced, cam belt replaced and I should have replaced the water pump - did it about a week after the conversion hit the road. Easiest way to do the Engine and gearbox - out from under: I cased an L series gearbox in a set of EJ front cases to avoid an adaptor plate and an EA clutch. This conversion is all EJ clutch and bolts straight up without issues: The initial test was a bit of fun in the paddock - I should've put the bonnet on though, it wasn't fun to clean! All fits in like it should be there. The L series should've come with the EJ from the factory, it's a great combination! Out at Robe, SA: After a chance purchase of a lifted L series, in one weekend the swap was done and Ruby Scoo grew to this: More fun, Otways, VIC: A few years down the track and a lot of searching I managed to track down a set of the infamous Scorpion 14 inch rims, these ones with the awesome general all rounder Wild Conqueror Super Trippers (can't get them anymore ): Robe, SA: Wyperfeld NP, VIC: Lerderderg SF, VIC: After two seasons at Mt Hotham and a 4wd'n trip with a "rally section" on the Dinner Plain Track south of the township I got Ruby Scoo airborne unintentionally. Not realising for some time but I did some extensive damage to the suspension mount on the LHS. Not ready to part with her I stripped her out and went to work between other things: While everything was reinstalled I added power windows, mirrors and central locking. That took a pot load more time than I anticipated and blew out the build time. I would say this took me 6 months over the summer period to sort out and get back on the road. Return to the road: Getting back into the thick of it: Mt Cole: Getting out in the High Country with the Subaru Club of Qld (offroad club, can't remember their official title) - most of these guys are online mates from ausubi: Basalt Knob South Tk before it was switchbacked: Back at Mt Hotham for another visit (Love this place!) New "trick" gearbox - L series AWD locking centre diff, front OBX (cheap!) LSD, 1.59:1 low range, low range oil feeders and 4.111:1 diff ratio (old box 3.7:1 stock ratio): Diff locking mechanism: This was an awesome mod - the diff ratio change has transformed the drive for the better. The ratio matches the tyre size the same as the foresters run so it's a tried and tested setup, just not really done in an L series in this fashion on a regular basis. I added a snorkel for added confidence during water crossings: This was 2013. For the christmas period we were planning another road trip to WA to catch up with some mates I made over there on the cruise in 2007. Unfortunately after finally getting my AC sorted the Head Gaskets let go. Not a bad run so I shouldn't complain - just the timing over the silly season slowed down the new parts arriving in a timely manner. But she's sorted again and running very well. First time I've had an EJ stripped down like this: Where I think the HGs let go, wasn't major but enough to run hot on a warm day. No damage resulted, money saved there Back together sporting a new radiator conversion (N14 pulsar) and new thermo fans - a good setup so far: Over Easter 2014 we ventured into new territory out at Walhalla in the foothills of the Vic Alps: First real good use of snorkel - Fulton's Creek Tk, Walhalla: Messing around, Fulton's Creek: Trig Track - 12 switchbacks! Loved this area and seriously cannot wait to get back out there! Last trip most recently was to McKillop's Bridge (very speccie!) and the general Snowy River NP, VIC: ^ Pics do not do this bridge justice, it's very high, very long and has been flooded over several times! I was with a "different" cohort for this trip with some mates in larger, "real" 4wds: Ruby Scoo held her own: Until I managed to blow 2nd gear coming off throttle on a down shift from third. Nothing harsh about it. From here it was a tow job, not fun! Once back on a decent track - logging truck track - we decided to see if I could manage third, using low range as another gear. This was done to avoid time delays, rocks flicking up and damaging the front of my vehicle and my newish windscreen. It was noisy in the box but it kept going, at the time I was kind of past the point of caring. After stopping for the others to catch up (I was rally style, they weren't!) we continued but I think it was too much, once the oil settled in the gearbox bits had moved. At walking pace I ended up locking up all four wheels. We were trailered from there, trailer came from Orbost. Then another type of towing occurred a week later: ^ These guys were great, they let me park up for a week in their yard very cheaply! Near M&D's, not quite "home" though: The gearbox came out at M&D's before I took the car home as I was itching to get it started. Once the box was stripped we found this damage: I've since sourced an SG forester gearbox for it's stronger internals as Subaru did a big overhaul on the 1st and 2nd gearsets in these boxes along with a few other things. My bench looks like this as I work through the little hurdles that are thrown my way: I've had to modify a few things along the way, the low range synchro hub being one of them: Latest modification hurdle is the woodruff key for the 5th gear as I want to use the 0.87 ratio I've got in the shed, not the SG's 0.78 as that's what I used to have and I wasn't too keen on it at cruise: That's where I'm at. Using Redback (Brumby - more to come on this addition to the family!) as the daily which is what I got her for, but I can't wait to have Ruby Scoo back on the road and 4wd'n again. I'm also working on some surface rust I've found since removing the gearbox, this is a slow process itself and work/family/social life is getting in the way too. Weekends are not at home at the moment I hope you've enjoyed reading and viewing the pics. While writing this and looking at the large number of pics I've got I've surprised myself just how many places I've been with Ruby Scoo. Many more pics if you want to view! She's currently knocking on 500k kms... I've had many great times out bush in this vehicle and I'm hoping there will be a number of years of more good times to come! Just have to get it back together and out of the shed!!! Regards Bennie
- 21 replies
- 10
Hi guys, I'm new here and will definitely stay active. Recently bought a 89' Leone Wagon, called L Series over here in Australia and absolutely loving it for my daily drive. I'm trying to restore it as much as I can so I'll keep everyone updated with progress pictures! I'm in need of new tyres, and saw this wagon (NOTE: Not my car), and want these exact same tyres. Anyone have an idea on the exact size of them? I'm currently rolling on 13" rims. Thanks in advance!
Hi all! Im sort of new to this whole thing but here it goes, I have a 1987 subaru gl base with the stock EA82 engine in it. Im 16 and I certainly dont know all that much about cars so Im not sure what could be going on but ill try to explain, I had removed the battery and when I went to put it back in I placed the positive wire to the positive terminal and the black box thats mounted to the coolant tank popped and start to smoke. All three wires that were in it blew in half and now when I go to start it nothing happens. The battery was in correctly im not that naive but im not sure what I need to do. Any suggestions?
