Had to replace low-beam bulb on passenger side. I'm sure you know what a PITA that is. Anyway, I removed the airbox to get better access. I disconnected the MAP cable and undid a nut and a bolt and pulled out the airbox. But there is a SECOND airbox underneath with a friction-fit tube connecting the 2 boxes. There is no way to reconnect the second, lower airbox - it is captured by the frame, and it rattles around freely. So I put the car back together ( without connecting lower airbox ), and the thing runs like crap at highway speeds.
So how do I connect the lower airbox to the upper airbox? I'm totally baffled.
Thanks for your help
Bill
