Search the Community
Showing results for tags 'legacy swap'.
But it is. Unfortunately. I'm sorry to ask but there is no one else in this world who has tried hard enough to get this to work. Unfortunately there is no spark. So here's the project. It's a EJ22T from a 93 Legacy (Auto) going into my 86 Brat (Manual) with a dual range 5 speed transmission from a 85 GL. I did not see this engine run as it was pulled out from a wrecking yard. Compression is solid. Only 165'000 km on the engine and it looks like it was dealership maintained. Everything is hooked up "properly" as so I've been told by what I would call "Subaru gurus". These are guys who have done numerous engine swaps before. Everyone has been amazingly enthusiastic, supportive and generous with this project as I could have imagined. It is all very much appreciated. However we can't figure out why shes not sparking. There is power to the coil. Coil has been checked of ohms and swapped out with three backups, they are all good. Plugs have been checked for ohms, they're good. Cam and Crank sensors have been checked for ohms, they are good and swapped again with checked and good sensors. Five grounds in the engine are good. ECU has been swapped three times and they are all good. It is grounded. Fuel pumps hard, fast and fresh. I'v had to replace a few connections due to old/dried out cracked wires but everything looks and tests good now! We're out of ideas now which is why I ask the godly experts of this board. Any thoughts or ideas are very much appreciated. Here are a couple galleries of the swap so far! http://imgur.com/a/EjDxS http://imgur.com/a/N6NzX
- 18 replies
