Search the Community
Showing results for tags 'lift kits'.
Andersondesign-fab.com Well guys I’ve started building lift kits. All my kits are reinforced and built stronger than they need to be, providing a safe and reliable means of lifting your Subaru. I’m keeping the cost as low as possible to make my customers happy and see them wheeling there Subaru’s! Little bit about myself, I have an AA in Architecture, AA in Mechanical Engineering, my year certificate in machining and almost done with my bachelor’s degree in Architecture. I being working/loving on Subaru’s for over 6 years. Been working under one of the best Subaru mechanics, non-other than GD for over 2 year. On to the Lift Kits! This is what i have currently, I will warranty all my kits and parts them self, as i feel i will never have to, due to the over kill of strength. All hardware is included Kits will take up to a week to fabricate, depending on what i have on hand. And yes this is my original design and my fabrication. LIFT SPECS: All hardware is grade 8 strandard, all metric bolts are 10.9 grade. Top and Bottem hats on the front lift blocks are 3/16" steel, sandwiching 1/4" tube walls. Rear brackets are 1/4" steel with 1/4" gussets. All subframe blocks are 1/4" thickness. When any lift kit is purchased, installation instructions in PDF, along with your Invoice, are included. EA81 2" lift $320 Shipped EA81 4" lift $450 Shipped EA82 2" lift kit $180 Shipped EA82 2" lift kit W/ 1.5" Full sub frame drop $275 Shipped EA82 4" Reinforced rear brackets 70$ shipped EJ 1" Solid steel strut spacers. $200 a set Shipped. The spacers are tapped to allow the spacer to be bolted to the top hat of the strut, for a stronger bond. 98-08 Foresters 95-99 Legacys and Outbacks 02-07 Imprezas EJ 2" Strut spacers. $300 a set Shipped. I also have the 2 Bolt rear for the newer Subarus as well. 2" kits are off set for near perfect caber correction. Forester, Legacy, Impreza EJ trailing arm spacer $110 a set Shipped New Gen EJ $300 a set Shipped 2" SH Forester lift kit with rear trailing arm spacers $500 Shipped FIRST ON THE MARKET!! EJ-EA Adapter plate, 6061 Aluminum wet jet cut. Dowel pins line up perfect and have a snug fit.145$ Tapped,shipped in the US. EJ-EA harness Stripping OBD-1 $250, OBD-2 $200. Before: AFTER: Notes: -All EA82 lift kits keep the camber near stock, if not completely stock. -Wheel at your own risk. -Not liable for any damages not under warranty of ADF. More coming soon! Like me on Facebook and keep posted! https://www.facebook.com/ADNFAB Pm me or contact me at ADNFAB@gmail.com for questions and inquiries!
HighGuysLifts.com is up and running. Site is still being improved, and as of yet we don't have a "shopping cart" feature. And it's lacking pictures......soon to be upgraded. But for anyone interested, we have a list of Lifts and Prices in the "kits" section of the page. Anyone who would like info, or would like to order a kit can e-mail to Info@HighGuysLifts.com EA71, EA81, EA82, Legacy, Impreza, Forrester and Outback. We make kits for them all. GET YOUR SUBARU LIFTED!!! HighGuys!!!
I'm thinking of doing a lift on my Brat (1983, so it's an EA81) and have three questions: 1. Is there anyone that makes a 3" lift kit for EA81? 2. How close can you get the tire to the wheel wells before they will hit once the suspension is compressed? (I measured 15" from hub center to the bottom of the fender. Without doing a lift, if I ran 28" tires, would they hit the wheel wells ever? Would I have to go smaller than 28" tires? In other words, would 1" between the tires and the fenders be enough distance to keep from hitting?) 3. I heard from AKghandi in a different topic that, "On an ea81 you have to drop the subframe when you lift it. Otherwise your cv axles will explode." What's this mean/is it valid?
HI GUYS !!!! i'm new here and my first question is, how can i raise my 1984 Gl Wagon another 3-4 inches to allow for a rugged rim/tire combo? is the best option a lift kit? and whats the best rim/tire setup? keep OFFROAD in mind when answering (snow, mud, sand, water...) the pic of the Subaru below is the GOAL !!! so please help. i've seen posts and discussions regarding "ozified" and "scorpion subaru" lift kits but when i search these, it seems they're no longer being produced or don't exist !!! thank you -Mr. SIX9
- 3 replies
- lift kits
- suspension
- (and 6 more)
