Search the Community
Showing results for tags 'll bean'.
So. I bought a 2003 Outback LL Bean with 196k. The car is in reasonable shape and runs pretty well except a slight hesitation and sometimes it idles a little rough/vibrates at idle. The main issue I'm having is that it likes to kick out about 1-2 cups of coolant every time I top off the radiator, it doesn't seem to keep pushing out coolant after that but it will have a very slow bubbling from the overflow hose into the tank at idle. I tested with a combustion gas test kit and after 2-3 min of testing the fluid hadn't changed color in any noticeable way. I do not see any active coolant leaks, maybe there is some seeping slowly but not that I can find. The only time I see coolant actually leaking from the car is if I keep topping off the radiator without removing some from the overflow. Also no strange smoke on cold starts, no contamination in the oil or transmission fluid. Currently I can just top off the radiator every morning and drive it all day (about 100 miles a day of stop and go traffic) and it never overheats; although the primary radiator fan does run a bit more than I'm used to with my other car (95 ej22) but that's it. I have replaced the radiator cap with a "safety" style and an OEM cap is on order; but I haven't changed anything else. I'm thinking a coolant flush, new OEM radiator cap and thermostat would be a good start but I'm not sure if any of those (besides the cap) could cause this issue and I'm wondering if I'm seeing the start of a head gasket failure but not enough at idle to show up on a test? Maybe a partially clogged radiator? Any ideas or advice are welcome; especially if you have experience with similar issues with an ez30d. (aside from things like telling my my engine sucks or I should buy another car...lol)
I just purchased a '02 Outback LL Bean ed. with the 3.0L; I know with a heavy SW like the Outback it tends to sway and dip pretty good with aggressive turns and big dips, but I'm relatively sure it's time for a KYB strut upgrade project... I've heard rumors that Forester struts of some year models will be a direct bolt-in with the '02 OB and provide a stiffer ride/slight lift; has anybody tried this? What model of Forester struts do I need to fit into my OB? On a related note, if I decided to install the OB struts, is the strut spacer a viable option for achieving a similar lift? Trying to make mine look a little sportier and give some extra clearance/stiffer and more controlled ride. Thanks! Any recommendations appreciated... PS Does anyone with the H6 have the whiney power steering pump? I saw the easy fix with the 4 cylinder (the housing adjustment) but the H6 has a different configuration... I've heard maybe the O-ring in the PS fluid line is going bad and sucking air???
Drove this LL bean for a bit over 200,000 miles, gonna miss it. Body isn't worth it for me to put in a used motor, it needs brakes, struts, pretty much every bushing. Runs great though! Keep to someday fix? Sell outright with proper disclosure? Part it out? Gotta think on it.
- 20 replies
- H6
- head gasket
(and 1 more)
Tagged with:
The title pretty much explains it. Hubby replaced the battery today and the o2 sensor (based on a code 51 reading). He then tried to reset the code with the engine running and found out that he wasn't supposed to do that. I don't know if that is the problem, but now the car will not start. I think it is "dead" and doesn't even try to turn over. I will correct that if he tells me differently. I need to be able to get to work and get my car tags, but cannot due to the check engine light. Help, please :-).
