Search the Community
Showing results for tags 'long block'.
I want to drop a fresh rebiuld into my Wagon befor winter kicks in. One way or another it will happen. But i was wondering if any of you guys have knowledge or experienced service from Enginehaus ?? Or Mark the guru?? A long block from enginehaus is 1695, and that is with shaved heads, bored cylynders, ect.. While Markthegurus long block is OEM spec and is 2000.. I want the motor to last as long as possible, of course a lot if that is up to me and maintainng it.. But my question is.. What would you do??
- 1
- enginehaus
- long block
(and 7 more)
Tagged with:
Just finished up some engine swapping and have an extra EA82 engine and a lot of engine parts. Including: - Short block 100$ OBO (NOT rebuilt. about 150k miles, cylinders are clean almost no ridge, was running, doesn't even need rebuild - just put back together) - Heads 25$ each OBO (needs valve job) - Long block 140$ OBO - Oil pump - Water pump - All pulleys - Valve covers - Some timing belt covers and the tensioners - Flywheel - Oil pan -Engine mounts - Ask if you don't see the part you're looking for, I may have it NO -Alternator - Intake manifold - Carburetor - Transmission - Radiator - Power steering - AC - Distributor email chasewell@gmail.com I can give you pictures or more history or information about any of these parts. Suggest a price for the little stuff if you are interested, let me know if you want the engine for a different price and we will discuss (via email)
