Hello to all, I need some help with my Subaru Legacy Outback 2012.
I live in Switzerland in an area where the winters can get rather cold but nothing under -15 Cel.
My Outback at around 60K km after a winter where I opened and shut the windows several times has made all 4 windows loose in their rails. Some of the times I tried to open the windows they wouldn't budge so I should have just never touched them in winter if the car wasn't properly warmed up.
I took off the front passengers side door panel and peeled back the plastic sheet and I believe it could be the bottom cable of the window regulator that is stretched. When I pull it the window has less play. Does anyone know if I take the motor and window regulator out is there a way to adjust the tension or tighten the cable in some way? Or should I just abandon this?
Thanks in advance for your suggestions. I linked a video to this post to show you what I'm talking about.
View My Video
