Search the Community
Showing results for tags 'loss of power'.
hello all- I have a 2000 Subaru legacy wagon, it's been a great machine. however I get a hesitation, and bogging. I'm not mechanically inclined, but I'd like some feedback from you who are. maybe an EGR valve? i've replaced the fuel filter, thrown several cans of 'sea foam'?? what could it be?? it idles and starts perfectly??
Hey all. I have a 99 impreza outback with 260k; just breaking her in . I was on the interstate the other day and i noticed i was slowing down a little, so I gave it more gas and it seemed to bog down and lose power i really had to stomp the gas to get her to go, even when it down shifted i could feel the lack of power. But when I let off the gas a bit i felt the acceleration come back noticeably. This went on till I got home form time to time. It didn't do it for a couple days then did it again on the hiway, and when I was coming back through town. It seems to happen when it warms up or has been running for a while. There is also a hesitation of downshifting now if not coming to a complete stop or giving it gas to pass someone. I checked the fuel pressure pre-regulator and it was 35, would raise to 40ish when given gas but would drop back to 35 even with throttle open. I replaced the MAF sensor, but it was a cheap one and my car ran horrible with it so I'm guessing mine is ok, unless someone thinks I should buy another one and try it. I have new plugs, wires, fuelfilter (although I think it may be flowing backwards), checked for vacuum leaks (broke the port on the purge solenoid that runs to the intake manifold), and checked to make sure the knock sensor wasn't cracked or anything. Any help with this would be very helpful as I have a 1700 mile trip coming up in three weeks!
- 9 replies
- lean
- acceleration
(and 2 more)
Tagged with:
I was driving our 98 Subaru Outback when I first drove I noticed the rpm and speedometer needles were going crazy. We entered the high way and the car started to run very rough, At this point the radio died, the RPM and speedometer stopped working, as well as the air conditioner. Before we could pull over the car was not long getting gas and the motor cut off. Once we were pulled over the car was very sluggish to start at first, would run for a few minutes before everything would start to give out and not work. After about three attempts to start the car it would no longer turn over. Just the starter clicking, The dealership ( FORD) we broke down in front of told me it was an electrical issue and would be very expensive. I called a Subaru dealership and they said alternator, I can do the alternator myself. I just need some thoughts.
- 2 replies
- alternator
- dashboard failure
(and 1 more)
Tagged with:
Greetings to all here in the Ultimate Subaru Message Boards, I recently purchased a Subaru wagon and am having various issues with which I hope some of you can help address. To begin, I purchased the wagon off of Craigs List in the Skagit area of WA. It was originally advertised for $500 and the ad was verbatim: "Its white got the roof rack won't go over 40 mph 4x4 push button stuck on..have title in hand and it runs but i will tow for maybe alittle extra..call me up...not a daily driver project for mechanic...probally a quick fix and flip..." Here's the link: http://skagit.craigslist.org/cto/3871124465.html After asking about the 4WD issue and what else is wrong with the car, I managed to talk the seller down to $400 vice the original $500 price tag. I shelled out an extra $50 for him to tow it to my place and that was about 2 weeks ago. To clarify, it's a 1992 Subaru Loyale Wagon 5-Speed SPFI 4x4 non-turbo (VIN 5). Considering the condition of the body, interior and engine from what I could tell, the car's a decent enough deal. The car starts, runs, drives, and stops, but not as well as it should. Before I get too much into the issues and what's been done thus far, please keep in mind I don't have much automotive experience. It wasn't until last year when I purchased my 1st Dodge Ramcharger that I started tinkering. Since then I've worked on another Ramcharger, an '87 CRX, and a '90 Civic. I can manage air filters, fuel filters, spark plugs, spark plug wires, distributor caps/rotors, ignition coils, bulbs, headlights, lift supports (hatches), fluid checks/changes, and things of that nature. Basic stuff. I also try to utilize the proper terminology so that I know what I'm referring to when at an auto part store or when getting insight from my mechanic buddies. So, on to the laundry list... - Engine backfiring, - 4x4 won't disengage - Loss of power - Grinding/"whirring" noise in front tires when slowing down - Stalling - Worn bearings/brake rotors? When I first got the car, I started it up and tried reversing. The car stalled out in the clutch-to-accelerator transition. I started it back up, cranked the RPMs to 3k and pulled back into the parking spot it was in. So far I've replaced the spark plugs, plug wires, distributor cap/rotor, and fuel filter as well as giving the car some love with a wipe down and bath. As of last night, my mechanic buddy took out the rear driveline after realizing the lever for the 4x4 (underneath the car) wouldn't budge. I think my transfer case is screwed up, but I don't know for certain. My buddy told me we'd need a lift or floor jack to get the car up high enough to diagnose it better. After he took out the rear driveline, I took the car around the block and it did in fact drive as if it was in FWD vice 4WD. However, there's an odd "whirring"/grinding noise coming from the front tires. It doesn't happen when I apply the brakes, but instead when I coast and am slowing down-thus why I thought it to be bad bearings. Also, the car backfires, has loss of power (RPMs surge, but acceleration is slow), it hates hills with a passion and will stall out easily on inclines. I personally think I either need a new fuel filter and/or intake manifold gasket, wheel bearings, timing redone, and a general tune up, especially with the SPFI. Again, I never claimed to know what in the wide world of sports I'm talking about when it comes to automotive, but I do follow the repair/owner's manuals step by step and to a "t". Any advice is greatly appreciated. More pics will come soon. Andrew
- 38 replies
Ok I'm lost again. My husband and the subaru dealer said my car was acting fine now that they reset the computer. I drive it for about 5 hrs afterwards and the engine light turns on and we're having the same problem again. Guess the throttle position sensor didn't work. Here's what it's doing.... when I stop... sometimes not all times... I can depress the gas and no matter how much I push the pedal it will pull out at around 5mph. When it really acted up I even tried flooring it and the car crawls away 5mph then all of a sudden it acts like the gas kicks in or the engine realizes that I'm accelerating and it jumps. Any ideas are greatly appreciated. Haven't run the codes yet but I will asap and keep you posted.
