Search the Community
Showing results for tags 'luggage pictures'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Just documenting for Rugby and any others who may find it useful some pictures of the installed luggage rack. Photos; These three screws are all you use to hold it down on the ends. The fine thread screw (far right) is used on the rear-most hole in the trunk. It goes in to a metal stud which I will show a picture of below. The two coarse threads go straight in to/through the sheet-metal. Rear-most hole has a stud installed. Forward most hole (below) straight in to metal. Small gob of silicone around it. Because some of the metal inside the trunk is double-walled, you can't see 90 percent of the screws driven through it. Instead you only see two, from the two outer - inside strips. They are capped with rubber. Rubber removed. Last but not least, the best way I see for lining up all the strips is seen below The center strip seems to be perfectly centered with the Subaru logo. Eye the rest out from there. The two outers that attach to the wing on the back as you can see attach pretty close to the edges of the trunk. Hope these are helpful!
