Greetings-
I just bought a '95 Legacy LS wagon with the EJ22 engine (EA4T with 143k) for cheap ($500) because it needs head gaskets. I'm going to do the work myself (first time for this repair) and I'm wondering if anyone in Northern VA area has a recommendation for a shop that can machine the cylinder heads after I remove them. I live in Springfield for reference.
I'm going to pull the engine to do this so I am going to do the timing belt/water pump (of course) and already saw some discussion about the eBay kits with the Aisin water pumps (which looks like a great deal). I also see that there is decent amount of gunked on oil on/below the block so I am going to clean the block and investigate that and figure out what else I need to do (e.g. oil separator/baffle plate, etc.).
I'm still trying to figure out which head gaskets I should use. I know the consensus for the EJ25 motors looks to be a HG with MLS. How about for the EJ22...do most people use an OEM head gasket? Decent aftermarket like Felpro that is similar to the OEM? Or some other aftermarket that is superior to the OEM?
Any info is appreciated.
