Search the Community
Showing results for tags 'master cylinder'.
  • Search By Tags
    • master cylinder ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 7 results
  1. How often should brakes need to be serviced? I have a 2012 imprezza and I've had the rear calipers replaced in 2013 at 11000 miles. Then my brakes were soft-- march of 2015 the brakes were bled and they installed a new master cylinder . Brakes were soft again in November of 2015 the brakes were bl...
  2. About a week ago I put new pads, rotors, and calipers on my Legacy. The brake pedal travel had been a bit troubling, going fairly close to the floor. I was hoping that bleeding all four wheels would improve it, but it hasn't. Now the only thing I can assume is wrong is the master cylinder. Does this...
  3. Hey guys I am trying to figure this out. My folks' car is a 1992 Subaru Loyale Automatic 4wd. So they were telling me the brakes were getting more and more spongy, when I came to visit them and checked out the car the pedal would pretty much go all the way to the floor. Now I had done the front b...
  4. Dear Folks, I have a 89 g10 wagon. I tried to look up some threads but no luck. I am replacing the master cylinder and keeping the plastic reservoir. I unscrewed the phillips keeper screw at the base of the reservoir. Can I pry the reservoir off without mashing my seals? Any help would be appre...
  5. In the process of converting my drums to disks, I noticed the seam around the middle of the Reservoir starting to leak. Anybody know where one can get another Reservoir and not the cylinder, especially when they sell the cylinder without the Reservoir?
  6. Hi guys. I redid all my brakes a year ago and bled the lines (first timer) and my brakes came out almost non-existent. Pedal to the floor and no action. The garage rebled my brakes and it was much better but they weren't terribly strong. Before me changing them, the pedal would not got to the floor...
  7. I am looking into replacing the master cylinder for the brakes system on my 1979 brat in order to pass inspection (and feel safe enough to drive it on the road). I am located in denton, Texas and am new to the forum. All help will be greately appreciated. Thanks -FunkMonk
