Search the Community
Showing results for tags 'motor swap JDM to DSM 2.5'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. I have a 2004 Forrester wagon 2.5 motor. Car is an auction car I bought and it was obviously a timing belt issue so rather than try to repair this I opted to get another motor. I bought a JDM motor from a local importer where ive gotten many good motors for other cars before I finally got the motor all installed. As per JDM guy I swapped the cam pulley and the crank pulley, injectors fuel rails plugs( new) old ignition wires and coil and used only the long block so the original motor from my car provided the intake, harness throttle body and EGR tube I also swapped the flex plate Car starts and runs but appears to have a miss in only the #1 cylinder. I had a set of injectors from a 99 motor and swapped one injector and still no change miss seems to go away at higher RPMS also getting a code for an evap leak and TPS .. swapped the TPS with another I had same thing... any input before I tare off the front of the motor again to make sure I have timing correct but im positive I have both cams and the crank at 12 o clock..
