Search the Community
Showing results for tags 'neutral safety switch'.
  • Search By Tags
    • neutral safety switch ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 5 results
  1. Hello, I'm having a really weird problem and having been able to pull up anything in my repair book, online or on the forum here. A lot of that has to do with not really sure how to word the searches. The temperature has started dropping and ever since it got below zero if the car has sat for a...
  2. I am having some trouble with my 1999 Subaru Impreza Outback Sport. I was out driving the other day, simple point-a to point-b, and when I arrived home I put my vehicle in park and turned the vehicle off. However, when I took my keys out of the ignition and took my foot off the brake, the vehicle be...
  3. Alright i have a 95 legacy wagon i love the car but got a few problems my main one is while driving it loses all power then kick backs in sometimes it will die but firw back up my check engine light ia on and says neutral safety switch. So my question is could that be causing it to just shut off ran...
  4. 2002 H6 3.0 auto won't crank. For the last month when the car gets warm it would not start (just silence). Always started after sitting overnight. Now with the weather getting warm, after sitting for a day and a half its just silence apart from fuel pump and starter relay click, dash lights good....
  5. Hello All, My 98 Forester with an automatic tranmsission has just recently decided to not start. I thought it might be the starter so I pulled it and took it to a shop and had it tested. It came back ok. I put the starter back in and the car started. The car will sometimes start and othertime...
