Search the Community
Showing results for tags 'new battery'.
Greetings all, 2003 Subaru Legacy (non-wagon). Initially had intermittent starting issues. If left to sit or most times a jump-start would fix it. New battery, same issue. New starter, would not start at all. Battery terminals and fuses all appear good. Ignition switch lights all indicators. In key starting position, does not give a loud solenoid click like I would expect. Voltmeter on ignition lead to starter gives me about 2v with key in the starting position. Key in start position does not dim or otherwise affect other indicators. If key is in run position, I can start car with a jumper between the battery and the ignition spade on the starter solenoid. Have pulled the steering column lower shroud and have 12v on the of the 4 terminals on the ignition switch when in the run position. In start position, the 4th position gets 12v and one of the existing positions that had 12 in run drops to about 2v. Bridging between contacts on the back of the start switch does not roll the starter. Reading codes did show a P1518 (ignition start low) which has not come back since cleared. Picking up a manual later today, but looking for ideas on where to look. A lot of suggestions pointing to a starter relay, which I'm yet to be able to find. Other suggestions point to the park/neutral switch - some say is accessed by moving the shroud by the shifter, others from below on the side of the tranny - not sure where to look for either one. Running the gear-shift through the gears with the key in start position has no effect, other than you can hear a relay "clunk" whenever you go to pull it out of park. Any ideas on how to narrow this down further guys? Thanks, Rob
