Search the Community
Showing results for tags 'no awd'.
I have had some experience repairing various fails of the duty c system. recently I had a solenoid fail mechanically bleeding off atf failing to lock the clutch packs yet the solenoid ohm tested fine and did not throw a tcu code. this all resulted in front wheel drive only this video depicts how I use air pressure to open the valve body and make sure pressure is applied to the clutch disks. https://www.facebook.com/video.php?v=10154906353260372&l=4129290750931752898 there are several writeups on how to get to the tail section but I do plan on doing my own with pawl instructions! the one I did find in USRM the guy had a loose one he HOPED would not lock up on him.... GEEZ X.x
- 4eat
- auto trans
(and 5 more)
Tagged with:
Hi all so I have had some headaches with this and never found a decisive video on how to test the rear lockup system I recently had no rear wheel lock up but no TCU code either so this is what I found and how to test the system for functionality before reinstalling into the car. https://www.facebook.com/video.php?v=10154906353260372&l=4129290750931752898
