Search the Community
Showing results for tags 'no heat'.
Hi All, This is my first post here. I recently did a timing belt on my 1999 Legacy Outback Wagon, with a new water pump. Job went well, all parts bolted up and timing came out fine, no problems running now. However, even after burping the cooling system with a radiator bucket, multiple times, the car still overheats and I don't feel heat. There are no signs of a blown head gasket that I can tell, the car runs fine and doesn't smell or smoke or anything, has full power. What should my next step be? I replaced the thermostat with a genuine Subaru thermostat. My water pump is one of the old style pumps, with the teeth as opposed to the disc. Help!! I'm not sure what to do!
- 10 replies
- blows cold
- no heat
(and 4 more)
Tagged with:
I have a 91 Loyale with a problem the has me scratching my head. Since I inherited this great car its had this weird (at least to me) problems. In the summer thetemp runs at the high end of the normal range, if I turn on the A/C it goes into the red. And in the winter time the temp barely gets into the normal range and no warmer. I did have a problem with the A/C cutting out but solved that problem with a fix I found on this forum. but the issue with the heat/no heat I don't believe had any bearing on the A/C issue So 1. Runs hot in summer, with A/C on it overheats 2. I tested the electric fan and it runs, whether our not it come on when I'm driving I don't know, though someone told me if the a/c is on the fan should run. 3. Barely gets warm in the winter. 4. Shop Put in an aftermarket thermostat years ago with marginal change. Any suggestions?
- 5 replies
- A/C
- overheating
(and 1 more)
Tagged with:
