Search the Community
Showing results for tags 'no idle'.
My 1990 legacy didnt idle for about a week so i replaced the MAFS, cleaned the throttle body, cleaned the air intake valve, replaced the PCV valve, replaced the PCV hose to the air intake. After all that she finally idles but its really rough it bounces from 0- about 1000 rpm is there any reason it is still idling rough? fuel filter? im not sure please help me out
- 1 reply
- rough idle
- 1990 legacy
(and 1 more)
Tagged with:
I have a 1990 subaru legacy manual Trans and I've been having quite the idling issue. I just replaced the MAFS and she still won't idle what so ever. I'm planning on cleaning my throttle body and replacing the gasket to see if that helps. I've already replaced the top end throttle body vacuum line and it didn't do anything to help. I need some wisdom due to this being my first import please help me out
- 4 replies
- 1990 legacy no idle
- 1990 legacy
(and 5 more)
Tagged with:
I have 1987 subaru gl 1.8 l 2-bbl carburator. I had it tuned up last week. The fast idle no longer works when engine is cold. I have to use accelerator to raise RPM'S.till warm.Doesn't the fast idle cam control that?Did something come loose or break?Does any one know anything about Subaru gl carbs or how a fast idle cam works.No one in this town does. Need your help winter is coming! Thanks
